Thank you, I will definitely look into the solar panel suggestion.
I think he means to use HueForge to put texture patterns of materials onto building parts. For example, if you print the wall as a separate object flat on the build plate, you could put a HueForge brick texture on the surface of the wall and it could have a variation in the brick color and of the color and texture of the mortar in-between the bricks.
Oh, thank you for explaining, that is actually quite an interesting solution to get the colors to vary, thank you
LOL, following his reaction, I’ve decided not to continue explaining, but it appears you’ve got the gist of my suggestion.
