How to know when the bed needs tramming manually?
I have a Bambu Lab P1S and would like to know how to determine whether its heatbed requires manual tramming. I understand that the printer performs automatic bed levelling and applies mesh compensation during printing. However, this makes it difficult to establish whether the bed is mechanically aligned correctly, since the compensation can conceal deviations.
Could someone please clarify:
  1. Is there an officially supported, non-destructive procedure for checking the mechanical alignment of the bed without changing its adjustment? If not, why not?
  2. Is there a way to inspect the stored bed mesh, preferably as numerical measurements or a visualisation?
  3. Does Bambu Lab specify an acceptable tolerance or threshold beyond which manual tramming is recommended?
I would prefer not to perform an adjustment procedure unnecessarily, as I first want to establish whether adjustment is actually required before changing anything.
(I would have contacted Customer Service about this, but (a) Bambu seem to have abolished Customer Service and replaced it with a random text generator, and (b) to talk to the robot, I would have to consent to my data being used for AI training, and I don’t see why I should have to sign away my rights simply to contact a company regarding a product I paid good money for.)
Hi Sod,
Checking the bed level relative to the print head/nozzle can be done by simply moving the print head around manually to various spots on the bed (especially the 4 marked targets / near corners) and measuring the gap somehow. Ideally with a “dial” indicator (or digital equivalent) mounted securely on the print head (there are models for such mounts on MW and other sites). But any kind of shim or feeler gauge inserted between nozzle and bed would also work, as long as the bed is close enough to the nozzle tip.
Of course if the nozzle is super close to the bed there’s a real risk of running it into the bed while moving the head around, so definitely something to watch out for (OTOH if it’s gonna to run into the bed while moving then it’s clearly not level).
One could also run the official bed tramming procedure and simply not do any loosening or adjustments (just check the fit of the shim/feeler gauge or read an indicator).
Though looking at the P1S procedure… they have the nozzle contact the bed directly? Yuck. The way they recommend for other printers, like H2S, using a feeler gauge or shim block is better.
But honestly I don’t understand why this needs to be so “complicated,” running g-code to have the printer move the head around for you… then wait… or get out of the way… :person_shrugging:
  1. No, BL deliberately doesn’t want us to see this information. There are threads on the subject. It’s controversial.
  2. Not that I know of… usually they recommend tramming if trying to diagnose poor first layers and after some other attempted fixes don’t work (so, not the first thing to try).
Cheers,
-Max
  1. dont know
  2. there are 3rd party tools for the H2 whose names i cant recall but i used long ago dont know about P1
  3. don’t know
AI) i think you already did that if you use windows or google or whatever
You could just, like, print a large flat single layer sheet and see if it worked.
It only requires manually tramming if the compensation range is outside the programmed limits, and I don’t think anyone has established them. You could turn on compensation and run the head around, and if the height above the bed doesn’t stay the same (like measured with a shim) that would be one symptom of the tilt exceeding the firmware range and then a manual tramming would be required.
You’d think out of range would be something the firmware detects and reports as an error.
Bambus firmware never exposes the bed mesh for some (bad, imo borderline customer-hostile) reason
So to find if you need tramming you need to make it yourself. Graph out 9x9 and move the head around with either a gauge mounted to the tool head or with some shims. If you end up with a planar skew then yes you should tram
You could also print a large cross extruded high. then you can check front, rear, left, right if the walls are perpendicular to the base. if e.g. front is leaning inward and rear is leaning outward, that would indicate a bed that is tilted to the front.
If you follow the directions, there is no reason to fear the Bambu tramming procedure. If your prints are good now, you are unlikely to lose anything but a little time or make anything worse.
The procedure is only “destructive” in that you do lose the present setting. The tramming code begins by finding the current Z=0 position (Home) in the center of the plate and then lowers the bed a bit so changes at the three adjusters are always upward. If the knobs are not reset to be flush with the screw, each tramming check will gradually raise the bed until it runs out of adjustment.
Sensors in the bed determine the Home position by lightly tapping it with the nozzle tip, so that already happens on every print. The tramming G-Code lowers the bed between moves, so it will not cause plate damage.
When the bed is tilted beyond the ability of the printer to compensate, the printer will produce an error message. I prefer to make the tilt as small as possible to reduce the need for compensation.
Be sure that the nozzle tip, bed, and both sides of the plate are clean before tramming.
I recommend printing a larger knob like this, because the adjustment knobs can be difficult to grasp and turn in small increments.
Makerworld offers several variations, but the important advantage is the larger diameter, which makes small, precise adjustments easier.
The key phrase in the procedure is “…carefully turn the corresponding bed leveling knob until the printing surface barely touches the nozzle.” I find that this contact point is difficult to judge by feel, especially when working against the stiff springs. Instead, I put a small flashlight behind the nozzle, put my eye at the level of the bed, and watch the nozzle/plate gap as I adjust the bed upward until the light just winks out. Also, my Smooth PEI plate has enough gloss that I can watch the nozzle meet its reflection. The final adjustment only turns the knob about one degree. I think this method produces more consistent results than using a feeler gauge.
The P1 printers use the same bed levelling mechanism as my X1C, which I was able to upgrade a bit with the X1Plus interface enhancement. One feature measures the bed mesh at 36 points, then displays and saves the result. Printer maintenance was due, so I performed a “destructive” manual tramming procedure today. This is the result after manually tramming:
I can use my OCD tendencies and repeated tests to dial it in a little bit better:
The small change actually doesn’t make a noticeable difference in my prints. If I change the plate, change the temperature, or even run the test a second time, the numbers may vary by about the same amount. If a few hundredths of a millimeter matter to your models, you probably should be machining metal instead of using consumer-level FDM.
I’m sorry, I have to disagree. I’ve seen too many examples of “I didn’t know what was wrong so I manually trammed the bed and now I have another problem.” to call it harmless, especially for people who are inexperienced at it.
I try to actively discourage manual tramming unless you absolutely know that it requires tramming. And I use the word requires with precision, I don’t mean that the tramming could be improved. Unless it is out of compensation range, what does being out of tram actually hurt?
@Sod-Almighty why is this even on your radar? What condition are you trying to correct for?
