How to save Object settings as preset
So I accidentally got focused while the scope button was set to object…is there a way to save its settings for use as global or do you have to manually copy them back to the global via table?
I haven’t spotted a transfer method in Studio, I believe you need to manually transfer them one by one.
Just got my X1C, dropped one of me components into the bambu studio and started editing the settings for PC getting the quality down… after 5 prints and tweaks of the settings i got the part to look flawless… So i go to lock in this setting as my printer default settings and i was in OBJECT and not GLOBAL…
How do they not have a SAVE OBJECT SETTINGS AS GLOBAL???
The AI response on a search for this says simply move over to global and the settings from Object will move over and then save…
Ummm that is not the case… I assume this is was your issue also? You would think there was a simple save object settings to global option…
Thanks for spending hours setting your config…
Now just MANUALLY go back in forth and edit the GLOBAL… FML!
