How to tune your Bambu printer for dimensional accuracy?
try these parameters , not always great and some time needs adjusting per print that is X,Y
**The other i found helps **
But more often i just resize the object after first print, when really is needed found that was the easiest for me
Also sometimes adjusting line width and layer height helps
The main problem i have seen is from the shrinkage , and very slow cooling after the print reduces the problem
but then the cooling profile changes the percentage as well , so use the same cooling profile
As others mentioned very difficult to get to a good accuracy , but i have done it to sub 0.05mm, on 70mm object but too much hustle
