I removed the z-axis belt without fixing the heating bed. help please
Hello friends. Lines were appearing on the z axis of my p1s printer. Even though I lubricated the shafts, it did not improve. I acted a little hastily and removed the belt without fixing the heater bed. I placed the heating bed at the bottom with my hand, but I was hesitant to tie the strap. How should I center the heating bed? what should I do? Thank you in advance for your help.
Hello and welcome to the forum!
I’ve never done this myself but here’s the wiki on replacing the Z belt on P1 series. Does this help?
Thank you. there it is stated that the heating bed must be fixed. Unfortunately I skipped that step.
you will have to start over if you want to do it right.
did you manage to fix this as my belt snaped and the bed unleveled on mine.
Yes, I solved it. After removing the belt, I took the table to the bottom and fixed it with the fixing screws. Then I installed the belt, removed the screws and did the calibration and the problem was solved. I removed the belt unnecessarily, but I noticed that the tension pulley was not turning. In this way, I lubricated it and made it work.
