I tried making a “Code Snippet” and assigning it to an event, but I can’t get it to work.
Is this code correct?
motors = MotorsController()
led_1 = LEDController(“LED1”)
motors.set_forward_rate(1, 100)
motors.set_speed(1, 512) # ~25% speed
led_1.set_led_effect(0, 500, 255, 0b0001, 0xFFFFFF) # White
Check here, these two are working. Maybe that helps.
motors.set_speed(2, 1024)
time.sleep(2)
motors.set_speed(2, 0)
time.sleep(2)
motors.set_speed(2, 2048)
time.sleep(2)
And this:
led_controller = LEDController(“LED1”)
led_controller.set_led_effect(0, 1000, 5, 0b1111, 0xFF0000)
led_controller.timing_proc()
Thanks my friend, the motor snippet works, but the LED snippet doesn’t.
it works here. You sure about “LED1”? Important: don’t forget the timing_proc()
Yes, I’m sure, but I’ll try again later.
I too can not get the LED to work.
Is this the complete code I need to put in ?
Maybe this will help to get access to the LEDs:
SHIPPET 1 Turn on headlights and taillights
from leds import LEDController
led_vorne = LEDController("LED1") # Front LED
led_hinten = LEDController("LED2") # Rear LED
# Stop effects!
led_vorne.repeat_count = 0
led_hinten.repeat_count = 0
# Set LEDs MANUALLY
led_vorne.np[1] = led_vorne.np[2] = (255, 255, 255) # White
led_hinten.np[1] = led_hinten.np[2] = (128, 0, 0) # Red 50%
led_vorne.np.write()
led_hinten.np.write()
SHIPPET 2 Turn off front & rear lights
# Stop effects
# Turn off LEDs
led_vorne.np[1] = led_vorne.np[2] = (0, 0, 0)
led_hinten.np[1] = led_hinten.np[2] = (0, 0, 0)
It’s an example for two Shippets for a CyberBrick car … Take a look here!
Regards Birdy
