(New A1 owner / 3DP newbie). Maybe I missed in the documentation, but what are these other folder contents for? I understand including the test/starter models to get going, but what about the other folders? Should I be backing those up somewhere on my PC for safe keeping? When I buy some new micro SD cards as spares & format them as FAT32 if they are not already, would some of those same folders/contents also appear related to that? Or do I just export my print file to the root level directory on the card & A1 should see it & allow print job?
All the folders will re-create themselves as need.
Thanks, should I be routinely purging the contents of the folders? I’m not quite set up for Wifi control & noticed it was recording each print which I switched off for now. Just wondering if I should be keeping my card volume accessible although it seems to have decent room right now.
Pretty sure they auto delete as my P1S sd card always stays at around 15gb
It’s not really recording your prints like a timelapse. If you ever have a problem with the printer Bambu will ask for the logger & recorder folders, it will help them find/fix your problem.
You can format the card in the printer if you think it’s too full.
