Incorrect bed levelling?
Hi, anyone got any tips on re what might be causing this?
Guess it has got to do with the bed levelling?
Thanks,
D
IMG_3265
Looks more like poor build plate adhesion, clean it thoroughly with dishwashing soap&hot water then rinse well with water afterwards.
Thanks for the suggestion. Tried cleaning the plate but had the same issue. Then tried another plate that too gave me the same problem.
ny thoughts are more than welcome!
Possibly a issue with wet filament?
What Filament are you using? Is it calibrated and dry?
Bambulab PLA-CF, been dried for six hours in a Polydryer.
WIll try with another PLA straight out of the dryer.
When I was taking the PLA-CF roll out of the AMS it couldn’t pull the filament back, got an error code. Maybe something is off with the feeding on that slot?
I would just try a different slot if that doesn’t work, try drying the filament
Yeah, stuck a roll of Polylite in that slot and it works great. Wonder if the abrasiveness of the CF filament caused too much friction. Gonna try to print something with the roll of CF not fed from the AMS.
