Induction hotend not centered between magnetic jaws / ferrite core
Hi all,
I’ve got a new H2C printer, and so far, I am happy with it. A lot happened since I first got a X1C with 3D printer development, it seems.
However, I noticed one small detail and wonder if it requires my attention. The induction hotend sleeve is very close to the ferrite of the induction coil (see photos attached). It’s so close I cannot tell if it’s just close or already rubbing, but I figured it might prevent the nozzle from seating correctly in the cone below, if tolerances of another hotend are maybe a little different.
Is this common? Is it fine, or will I get problems with this? Would it be possible to shift the ferrite part slightly to the left by loosening the bolts you see behind it on the photos?
Thanks for your help and opinion on this!
Best
Phil
