Infill Overlap?
Hey all, trying to diagnose the under extrusion around my circles. Would this be resolved increasing infill Overlap? Just running base settings for Bambu Lab PETG
Hello
On h2s i also see an issue with that (not on a1 mini). I need to do more test but 18% seem better
On questions like these photos can really help others see what you are referring to and would possibly get you answers sooner.
Sorry, i actually thought it posted one. I’m updating the original post now with the photo
If you’re sure the pressure advance is correct, then you have a couple options:
Enable small flow compensation
Increase wall/infill overlap
Slow down top surface speed
Also remove “reduce infill retraction” to hopefully kill some of those stray lines at weird angles. (Assuming your filament profile has z hop enabled, a default)
