I have been browsing through some past conversations regarding creating and sharing models and I am curious if anyone has worked out whether or not there is a difference between being inspired and remixing.
It seems that remix has more or less a clear definition being something along the line of using the digital file from another creator and editing or otherwise modifying it. It also seems to be considered if one was to start over from scratch but arrive at a similar place that a model still could be considered a remix. The exception seems to lean towards the functional aspect of a design - two hooks may look alike but the nature of a hook means that both models can be original even if both look like hooks.
I ask because I have made a model from scratch that is heavily inspired by another model. This model is an assistive device for opening bottle caps. I built my copy because the original was limited to a few bottle cap sizes and I wanted to be able to adjust to fit more types of bottle caps. I felt pretty confident at first that I was just inspired by the original, especially since I started over from scratch. However I realized by the time I finished my model that I also copied the overall shape and appearance of the original. While my model can have more options, when sized to match the same bottle caps it looks very much like the original.
Now, I can go back and redesign the handle. The mating part to open the bottle I feel is going to fall under the âhookâ example I used above and I feel if I avoid a pure copy of the handle I could claim I am now at best inspired by the original. Am I correct to feel this though or is it still a remix? At what point can I start to claim the model is mine and not someone elseâs? I want to be able to share mine - I think the extra sizes are worth having and sharing. I also donât want to be yet another jerk who steals stuff. I know I put the work into this, and I feel the basic shape of a bottle cap opener is more or less described by the bottle cap, not the designer of the opener. I canât argue though that I saw the other one first. There are many boxes, trays, coasters and so on that one could argue are somehow all copies of one another but at the same time each original versions of each other. If one is inspired to create a new box based on seeing another is that a bad thing?
I am assuming this is a sensitive topic for all the creators here. I hope that time has helped some people come up with a clearer answer than I could get from the past. Maybe I missed a guideline published by MakerWorld or another similar site facing similar issues. I donât know. I probably am just hoping everyone here just tells me I can do whatever I want. Either way, I havenât shared my file yet and maybe never will if it really is just a remix.
