Intelligent Parametric Enclosure Generator 2.0 — Now Open Source
I’ve just released Version 2.0 of my parametric generator! :rocket:
If you’d like to support me, a like, download, boost, or share goes a long way. It’s completely free, open source, and built to save you time and effort — feedback and suggestions are always welcome! :raising_hands:
:backhand_index_pointing_right: Smart Parametric Enclosure & Junction Box Builder - Free 3D Print Model - MakerWorld
I was tired of designing a new enclosure every single time I started a project. So I built a system instead.
Introducing the Intelligent Parametric Enclosure & Junction Box Generator 2.0 — a powerful open-source OpenSCAD tool for makers, engineers, and electronics enthusiasts.
:toolbox: Modular. Customizable. Precise. No CAD skills needed — just adjust your parameters and print.
:wrench: Highlights
  • Smart sizing system • 10 presets (Mini → XL) • Fully customizable: L 50–200 mm, W 40–150 mm, H 30–100 mm
  • Mounting options • Wall-mount holes (adjustable spacing) • Corner posts (Ø6–15 mm) • Optional M2–M5 threaded inserts
  • Advanced lid system • Flat, inset, or raised • Snap-fit or flush screw-mount • Adjustable lid thickness (1.5–5 mm) • Screw head types: Phillips, Torx, Hex, Cross
  • Internal threading toggle • Smooth or threaded posts for direct screw insertion
  • Cable management • 0–4 ports per side • Adjustable port height/diameter (4–20 mm)
  • Structural reinforcements • Optional internal bracing • Adjustable fillets, ribs, and strength
  • Print optimization tools • Tolerance tuning (0.1–0.5 mm) • Curve resolution (30–120 segments) • Multi-part bed layout support
:printer: Suggested Print Settings
  • Layer Height: 0.2 mm
  • Walls: 3+ perimeters
  • Top/Bottom: 4+ layers
  • Infill: Gyroid 20%
  • Materials: PLA, PETG, ABS, ASA
:light_bulb: Use Cases
  • Raspberry Pi or Arduino enclosures
  • Industrial control boxes
  • Home automation projects
  • Power/network junction boxes
  • Robotics and sensor modules
Steel screws are fully supported for strong, durable fastening.
Want to help improve it? Try it, break it, tweak it — and share your ideas.
Together we can make this the last open-source enclosure generator you’ll ever need. :wrench::rocket:
