Ironing looks terrible on X2D
Thank you for your comment :slight_smile:
There are some difference between x2d…
Can we see a comparaison between your two x2d ?
Thank you so much
Do you mean pictures of the difference in the print quality, or the actual printer?
Sorry, I meant photos of the same part, with each one printed on one of your X2Ds, using the exact same settings on both printers.
Thank you for the photos.
This is indeed the same issue we identified previously, and we are very glad to have another user’s testimony confirming the same behavior.
The problem is therefore very likely related to the firmware.
In orange, we can see a line corresponding to an infill geometry that appears on “complex” surfaces. This particular issue is not caused by ironing itself. It would still be present even if the part were printed without ironing.
In black, the lines appear at the tangent points of the circles (and they would also appear with other geometries). They correspond to the nozzle movement when the firmware creates a new ironing area in order to maintain the angle specified in the slicer settings.
At this point, there must presumably be a change in extrusion flow and/or cooling/ventilation parameters occurring during these transitions, which would be controlled at the firmware level. This could explain the visible difference in surface finish.
One possible workaround at the moment would be to optimize the model’s orientation in the slicer. However, this is obviously not a practical solution, as it cannot be applied consistently to all models and geometries.
It is also quite likely that all newer extruders using the PSM architecture may exhibit the same behavior. This would need to be confirmed through controlled tests on the H-series machines.
From what I understand, this should potentially be addressable through a firmware update. I believe the P2S already has an experimental firmware update available on GitHub aimed at addressing top-surface geometry issues, although it does not appear to address the ironing-specific issues we are seeing here.
So, @SupportAssistant, what do you think about this analysis? Could the firmware team investigate whether these transitions involve changes in extrusion flow, pressure compensation, cooling, or other firmware-level parameters that could explain the ironing artifacts?
If this is indeed firmware-related, a firmware update would obviously be a much more appropriate solution than requiring users to modify their models or orientations.
Have you tried concentric ironing on your piece ?
Yes it was a disaster, I think there is something to this in the tool path direction changes. The concentric amplified the issue with smooth glass like finish on the starting side-left, and rough digging in on the right. I’m doing some more testing right now with a long 200 mm piece. The center 80% is glass smooth, but on the ends where it decelerates, and changes direction there is rough areas.
I also can confirm that I am unable to get decent top layers and/or ironing even after various time and material consuming calibrations. currently I am spending a lot of time to dial in general settings again (5th time) even flow calibration tests in bambu studio seems like a hit and miss with 3rd party filament.
This is the current calibration process I am trying: Advanced top surface guide - understand & improve - Free 3D Print Model - MakerWorld
Thanks for sharing this. I was able to use this process to find a setting that works well on both of my X2D’s. It’s still concerning that my original X2D, P2S, H2D, and A1 mini had no issues with my original file. I do believe something changed in later production units.
I do a cross post in this thread as this also shows off how good my top layers are now with “optimized” settings
Test Setup:
  • Bambu Lab X2D Firmware v01.02.00.00 (v2 hardware revision, bought mid of July 2026)
  • AMS 2 Pro, Firmware v05.00.22.19
  • Filament Buffer Firmware v02.00.17.18
  • FTS Firmware v00.00.16.65
  • External Exhaust Fan Firmware v00.00.13.35
  • Bambu Studio Beta v2.8.4.57
  • Bambu Lab Basic Black (Flow Ratio 0.985, Cooling a bit retarded)
  • Nozzle temp Initial = 220°C, other = 215°C
  • Speed set to 200mm/s
  • Top Surface 75mm/s, Monotonic Line + Sub Top Surface
  • Line width 0.45, Top Surface 0.32
  • NO Ironing
  • LAN Mode enabled
  • Flow Dynamics Calibration = off
I ran from left to right the same settings above just with the following difference:
  1. manual G-Code = M900 K0.00
  2. no manual G-Code, Flow Dynamics Profile K-value 0.001
  3. manual G-Code = M900 K0.021
  4. no manual G-Code, Flow Dynamics Profile K-value 0.026
  5. manual G-Code = M900 K0.027
Cheers :clinking_beer_mugs:
@N5BSB I just printed a long flat piece like yours. My result wasn’t quite as bad as yours but it was similar at both ends.
@SupportAssistant Has this been resolved yet?!? I have yet to get any kind of consistent quality ironing out of my X2D. I’ve had to sand and polish every piece I’ve printed where the finish matters, and that’s after wasting way too many hours and way too much filament trying to fix a problem I shouldn’t have. It’s disappointing that my current ironing setting is “I guess this is the best I’m going to get.” If there’s a fix, please post it here so I and others can have a usable machine. As is, I’m frustrated enough that I tell folks to pass on this printer when asked (which is often).
I posted the settings that work best for me for simple flat geometries with calibrated Matte PLA after a lot of trial and error and dialing it in, but for anything with islands or holes it’s still not great compared to my P1S.
I’ve had to resort to swapping back to my P1S if I need to iron something that’s not super trivial in geometry, which is incredibly disappointing. I tried to iron something with a basic square cut out this last weekend and the edges looked really bad.
So I guess to answer your question, it’s not solved for me yet and at this point I’m waiting on a firmware update or something.
To follow up on your excellent post from back then, I’m also sharing part of one of my post here. It might not be the solution, but maybe someone will find parts of helpful after all.
Proper calibration is essential, and a separate profile for each filament is highly recommended. More specifically, the flow ratio should be calibrated for every filament individually. After that, the automatic dynamic flow rate calibration should be disabled right before printing.
The next step is an ironing calibration. Here’s the twist: the ironing flow ratio will often need to be slightly higher than both the default value and the calibrated value used for normal printing.
Most profiles come with a default value of around 1.01 (depending on the filament, of course), but ironing typically benefits from a very slight amount of over-extrusion compared to the standard print profile.
In my case, the best results are achieved with a value of 1.0395. It’s only a very small increase, but it can make a noticeable difference to the final surface quality. Compared to the default settings, this produces absolutely perfect surfaces.
  • The ideal setup is to have one filament profile for normal printing and a separate filament profile specifically for ironing.
Of course, the exact values will vary depending on the filament, printer, and environment, but fortunately the entire calibration process usually takes no more than about an hour.
The sample photos are from a P2S, which suffers from the same issues, not from an X2D. So while the printer in the photos isn’t an X2D, the underlying problem and the calibration process are essentially the same.
  • The key point is: Both printers have unoptimized print AND filament profiles for ironing.
The first photo was printed with the default ironing settings on an P2S and looks pretty rough. The second one is perfect - optimized settings as described.
Keep in mind that these photos are extremely zoomed in.
Bambu default settings without a very slight amount of over-extrusion
Optimized settings with a very slight amount of over-extrusion
I saw Bambu released a software update. I scrolled through the list of what the update included. I was hoping to see “we fixed the ironing issue some people are having” but it wasn’t there that I saw. I did see see they added a new options to improve top layer finish. In theory, an improved, more even top layer could improve ironing along with it. Has anyone tried the new settings to see if it’s helped with the ironing issue?
