I’ve had to transition from PETG-HF to PETG Matte. I’m having difficulty getting Ironing worked out. I have a number of parts that have a large area that needs to be ironed. The issue is that when Ironing large parts, my P2S leaves ‘scars’ on the surface areas where the flow seems to studder and leave a short void. What I’ve found is that any time I try and print a line width of under 0.4mm (I’m using a 0.4mm nozzle), the flow becomes uneven. I’ve played with speed, temp, and flow volume and I’ve found work arounds for most of this except ironing. I was wondering if anyone has found a good settings for ironing with PETG Matte?
I’ve kinda solved the ironing issue I was having. PETG Matte (and I assume PETG Basic) lays down much differently than the PETG-HF I was using. It all came down to the top layer. The smoother you can make it, the better ironing becomes. In fact, I’ve gotten the top layer smooth enough in most cases that I don’t need to iron. For the top layer I use a 0.32 line width and a top layer flow rate of 1.15%. This puts the top layer lines close together and ‘overfills’ the gaps between them to the point where it comes out very smooth. Very pleased with the results. I went back to my old ironing settings of speed=70, ironing rate at 20%, and ironing line spacing of 0.2. With the exception of the starting corner, this worked out great (the starting corner isn’t bad, just not as good as the rest). This works for me with PETG Matte. Haven’t tried it on anything else. FYI, I use a HF nozzle as well.
