Is it advisable to print a large flat print 330mm wide on H2S?
The H2S volume size is 340x320x340mm. I’m thinking of developing a model that will be 330mm wide (basically a box about 330L x 260W x 200H.) This will leave only 5mm left on each side of the bed. It will need to be printed in flat orientation. So, I’m thinking about buying an H2S.
On my P1S, I had to disable the aux fan from such large prints to avoid warping and tweak temps, and I still had slight issues. Do you think that the H2S actually can print such a large flat print without warping at the corners?
Absolutely. I printed this on my H2D with zero issues.
H2 Series XXL Crate 320mm^3 by Ulade MakerWorld: Download Free 3D Models
Thanks for the input and example.
