This is product which is always being printed on my P2S, some prints turn out flawless, but sometimes its causes this shift mostly at the same height, in a batch of 4, 2 of them have this shift and 2 dont, Im using bambu slicer, also no settings are changed in between prints. The filament which is always used is Bambu Lab’s ABS
Printing on 0.4 nozzle with 0.2 layer height, only settings changed are support top z distance and wall generate Arachne and default tree support
Since you say that you are printing in batches of four and only two have the issue it sounds like you have a cooling issue. ABS shrinks a lot more than other materials. Where are the two located that have the issue vs the ones that do not in relation to cooling fans? Do you keep the printer lid and door closed during printing? Are there fans or windows in the room that could create a draft?You may need to change your fan settings.
