More than likely, it will ship with a full set of 0.4 nozzles.
But I wouldn’t be surprised if they sold a pack with a combination of nozzles apart from the machine.
If they’re touting multisize printing as a feature, I think there’s a good chance it will include at least one 0.2 and one 0.6 hotend in the basic config.
Probably in the box, I wouldn’t expect it to be installed. Just my opinion though.
Good lord that AMS is hideous. Function over form and all, but blech ![]()
Reminds me of the queen from Alien, but then the Tesla cyber truck always makes me think of Kryten from Red Dwarf.
Last 48 hours for H3C launch.
La H3C avrà 9 testine intercambiabili e la P3C ne avrà solo 7. Gli AMS saranno integrati sopra la stampante in questo modo: nella H3C avrà 5 bobine dietro e 4 avanti, nella P3C quasi sicuramente 4 bobine dietro e 3 avanti. Di conseguenza credo che le dimensioni possano aumentare leggermente. Per i prezzi la butto li… P3C 990 dollari, H3C 1990 dollari. Puramente scritti cercando di indovinare.
Was watching some H3c reviews and am now a bit concerned if the ams 3p will be able to automaticly load filament as the ams 3h uses a switching mechanism to use one servo to load all filaments and the ams 3p does not seem to have that mechanism, I’m hopeful that they are just using some other system but honestly it would be a big let down to not have autofeeding
Now that H3C is officially out, apart from a different number of nozzles and a smaller plate, what do you think will be the differences with p3c ?
In my opinion the price will be around 1490$€ since it appears that AMS is not an optional anymore. P series will have a new price range.
Not a bad point regarding the AMS, but I’d imagine they will want to compete with Snapmaker U1 for multi-color PLA/PETG crowd. If price is indeed north of 1000$, I’d imagine U1 still the easier choice?
I really wish the AMS WAS optional or that there was a bypass for each toolhead. My needs would be better served with a printer where behind every toolhead was the option to put an AMS HT or AMS 2 Pro. Or at least more than one of them…
I wish it was 6 nozzles and a option for chamber heating
You want to spend 2700 dollars on accessory boxes? Really?
Explain yourself lol
It could utilise the AMS3 concept used for the H3C. Which has the 5 front "ports for the spools, and 4 rear ports + 1 storage caddy.
But instead of 5 slots, it will be 4 at the front and 3 at the back ( 2 which have dryers), and 1 for softer more brittle filaments that are fed directly in the extruder, so you can have the filament spools at the back that require more drying, and a separate spool for other materials, that cannot go through the PTFE tubing. No drying for front ones.
They will no doubt use the same Smartek system for the nozzle changes and have the same doubly entry to the extruder (one for the PTFE tube, that hold filaments 1-6, and 1 for inserting TPU type stuff directly from the AMS. Think they will go with the 7 nozzles for the use of CMYKW, for the colour blending.
The plate is likely to be same as before 25x25x25, and most other stuff the same. Think they may not have a chamber heater.
So all in all, I think the only difference between the P2S and P3C is going to be that 7 nozzle changer, and mandatory AMS.
Price :- £1200 - £1500
So there are two very different products here between the P2C and the P3C. They are polar opposites on the filament flow. The P3C is limited to a single spool per tool / printhead. There are only two positions that can be dried. The AMS does not pull back filament. I’m not saying rip that out. (Well maybe( What I am saying is put a provision to install a bypass on more than one printhead. Want to print more engineering materials? Don’t use the AMS, install an HT behind. Want to switch more colors than 9? Install an AMS 2 Pro behind a few nozzles. Want to have the ability to load PLA and unload for engineering filaments? Have the AMSs unload the material that can’t have higher heat. Keep the AMS for the general usage, but allow for a more P2C approach if people want to spend on it.
I am usually wrong, so I’m wishing i am wrong on my predictions. The main difference i think will be no chamber heating and no dedicated AMS filament drying.
There’s already been plenty of leaked drawings showing this is exactly what it will be.
Edit: It’s already in the thread above.
That’s why I included it in my post. I just speculated it wouldn’t have 9 slots (10 if you include storage) but 8 (including storage), otherwise there wouldn’t really be any point in the H3C. Might be nice if they had some sort of return for upgrade thing too, where they give you £50 for your P2S and AMS2 Pro, to upgrade to the P3C, for a limited period.
