Is there a solution for bridging a doughnut shape hole yet?
Bridging solid areas works fine. But try for example a bridge with a hole in the middle - for example a counterbored screw shaft - and it does not work.
what the slicer should do is start bridging from the outer perimeter and concentrically go inwards until it reaches the hole, then stop, but it does not and the part just looks bad. it just to race straight over it, as if was a circle wihtou a hole in the middle.
Yes i know you can fix it by changing the design of the part, but seems like there’s a missing algorithm for this type of hole.
Support can help in some holes. And depending on the hole and purpose, you can make the ends conical where no support is necessary?
