Is this 2nd color possible to print in place?
Pretty new to 3d printing, I am using a P1s (no AMS) printer using PLA in Bambu Studio. I downloaded the files for this print here in Makerworld. The picture looks very much like the green is printed in place, there are 3 trees placed evenly around the circumference. Unless the ring is printed first, then mounted to the build plate on its side to add the green trees one at a time, I don.t see any way this is possible. Even then the concave shape would likely interfere with the nozzle. I would love to hear some thoughts if anyone thinks this is doable, I am puzzled.
Model file:
There are 3 ways to do that in your situation:
  1. Print single color, then paint the trees
  2. if the model allows - separate out the trees form the ring, print the ring with indents and trees separately in separate colors, then glue them together
  3. Get an AMS for P1S - looks like the black friday sale is up till Dec 3 and it’ll ship (in eu region at least) by Dec 13th.
Johnny, Thanks for the reply. If I were to have the AMS wouldn’t it have to change colors every layer in the tree area? If that is true it seems like it would take a very long time to print and create a huge amount of purge waste?
It is the trade-off.
Lots of layers with colours add time and waste.
You can reduce the time and overall time if you print several simultaneously.
Remember that the sale ends tomorrow (essentially), it is currently the cheapest time to purchase an AMS.
Thank you Malc . I took a quick look at the Bambu site and it is listed at $250, which I believe is the usual price. I could have bought it with the printer for $150 but really didn’t see the need. I suppose technically this would work, particularly if I ran a plate full. The wife wants at least 24 so that would mitigate the waste to some degree. I have printed the trees separately and they are fussy little buggers. I am sure as my manual support skills improve they will not be so bad, but using default auto supports made it impossible to separate the trees without breaking them.
There are benefits to AMS and one of them is having to print “at least 24” of such items - the waste stays contstant, but is shared among the 24 items instead of just 1 so the print-to-waste ratio is waaaay better.
No, but I can get close. I’ve redesigned it with a new method that prints in two parts. The outer ring is just the ring with holes for the trees. The inner ring has the trees coming out of it so they’ll perfectly slot into the outer ring. Files and photos soon!
Hope this helps!
(edited to remove stuff, I’ll post it on MakerWorld instead. Check version history for old info)
Very interesting work-around, clever. I work in Fusion so I will check out your tutorial, thanks!
I’ll post an updated version on MW that fixes the issues I encountered in a few minutes once it’s printed. Feel free to use that or make your own (if you post it on MW, I’d appreciate credit for coming up with the concept).
Thank you Zammer. Could you provide a link or some direction in finding this? I have not seen anything so far, but I am not well versed in the site geography.
I hadn’t posted it yet, sorry. Just released it now!
Assuming you are in the US…
It is currently $249.00, the normal price is $349.00.
This is a $100 discount by my calculations.
I recommend doing a test in Bambu Studio so you can see the difference in time/waste.
Paint one so it has the colours you require.
Add another plate and clone the painted one to the new plate, add as many as you can to the plate.
Slice both and see the time each takes and the waste it generates.
The number of filament swaps (the real big time suck) will be the same for both as will the waste material.
I like my method better, it’s waste-free and AMS-free lol
I was just about to reply to your first message with the video and decided not to.
Now I will.
You are cheating cheater!
:rofl:
Nice. Yours is flat and the OP wanted a curved one, which would be far more difficult to resolve in the same way the flat cylinder makes the insertion far easier.
This is, as far as I’m concerned, not flat.
You and your optical illusions are just trying to make my only good-ish eye work double duty at nearly 2 am.
Shame on you for your trickery.
You are doing it to poke a stick at the cripple, I know you too well.
My bad lol
