Issue at the seams - Weird worms
I am having a weird issue that is occuring at the seams when I print my deck box tops. I am new to 3D printing and I am only about 6 prints in. I have printed a few different things with no issues. But for some reason when I print out my deck boxes for TCG. I am getting these small extrusions by the seams (Picture attached). I have tried this print on both Bambu Matte PLA and Sunlu Matte PLA and get the same issue. My files look fine. I rotated the top on the second print to change where the seam is sliced and it is now happeing on the other side of the box where it placed the new seam. Any help or ideas would be great. Thanks in advance.
edge
That is most likely caused by the nozzle clogging detection in the settings of the A1/A1 mini. The tool head moves to the rear right corner of the build plate in regular intervals to check if an extensive amount of filament has accumulated at the nozzle. While traveling filament oozes from the nozzle. Just disable the function and the “worms” should disappear.
Thank you! Printing some stuff later today and will try it out.
That was the issue. Fixed it right up. Thank you for the reply. For anyone else that has this issue, the setting to turn off is on the actual printer.
