Printer: Bambu Lab X2D.
I am using both nozzles: the main nozzle prints the model, and the auxiliary/right nozzle is assigned to print supports or support interface layers.
The issue happens specifically after a tool change from the main nozzle to the auxiliary/right nozzle. When the right nozzle is supposed to start printing support, it moves along the toolpath, but filament comes out with a significant delay. Sometimes the nozzle just moves over the support area without extruding properly, then spits out a few small blobs of filament. As a result, the support does not form correctly.
Important detail: if I print a separate test object using only the right nozzle, extrusion looks normal. So it does not look like a constant clog or a complete feeding failure. The problem seems to happen specifically during the transition from the left/main nozzle to the right/auxiliary nozzle, when the right nozzle has been idle and then needs to start printing support immediately.
I have already performed manual Flow Dynamics Calibration for the right nozzle. In the newer version of Bambu Studio, manual Flow Dynamics Calibration for the right nozzle is available. However, the issue remained after calibration.
I have also checked Max volumetric speed and even increased it slightly. Support print speed is already reduced by about 25% below the maximum allowed value, but this did not solve the issue either.
Another observation: the first layer of support may print normally, but on the following layers the right nozzle starts under-extruding again or almost does not extrude at all.
I am not using a Prime Tower because the printer has two nozzles, and the second nozzle is dedicated to support material. However, I now suspect that the issue may not be about purging/cleaning, but about the right auxiliary nozzle not building enough pressure after being idle before it starts printing support.
What has already been checked:
printing a separate test object with the right nozzle works normally;
manual Flow Dynamics Calibration for the right nozzle has been completed;
Max volumetric speed has been checked and slightly increased;
support speed has been reduced by about 25% below the maximum allowed value;
the issue appears specifically after switching from the main nozzle to the auxiliary nozzle;
the symptom looks like delayed pressure buildup/filament flow after idle time rather than constant under-extrusion.
Questions:
How can I properly compensate for delayed extrusion on the X2D auxiliary/right nozzle after a tool change?
Is there a setting for additional extrusion after tool change, such as Extra length on restart, Pre-extrusion, or Prime amount?
Should I still use Prime Tower as a pressure-priming tower even though I am using two separate nozzles?
Which retraction settings should I check for the auxiliary nozzle: Retraction length, Retraction speed, Deretraction speed?
Could this be related to different right-nozzle temperatures after the first layer, such as Nozzle temperature - First layer vs Nozzle temperature -Other layers?
Could this be caused by the right nozzle staying idle for too long between support sections and losing nozzle pressure?
Does anyone have a working profile for printing Support Interface with the auxiliary/right nozzle on the X2D?
You’re my only hope! I’ve already tried everything.
To add: even if you print a model with the auxiliary nozzle and it turns out fine, the start of extrusion still has a delay, just like when switching the nozzle from left to right while printing supports.
