Joining statue to base
Is there a way to join the statue bust and the base so they print joined in makerlab
You can merge them in the slicer. Select both then right click and hit merge.
They both load together as one object but not joined. So the slicer won’t let me select them as 2 objects and use mesh boolean
Select the object, split it into objects or parts, move stuff around, finally re-merge stuff together like @Zammer3D explained and print.
