K Value (PA) should be a filament setting
How do we tell Bambu that K Factor belongs in the filament profile!!! How can We spread the word to make this update a reality??? ONE place for all things filament!!! THEN, in your device screen under your AMS slots, assign the filament PROFILE (which includes EVERY known filament setting including PA) to the slot AND BE DONE!!!
Currently PA is the ONLY setting disconnected from the filament settings. Its not a good workflow. PA is a derivative of flow rate which is a filament setting. PUT IT IN THE FILAMENT SETTINGS PROFILE PLEASE.
The user also has to edit or create ANOTHER profile in the AMS slot to hold the K factor?? NO! This is not an efficient workflow. As a production control/systems engineer, this is not intuitive, NOR is it convenient.
Make the AMS interface in the device section PASSIVE except to assign filament. DONE. EASY!
Work flow:
Put filament in AMS slot of choosing → AMS doesnt recognize filament → Create or edit your own filament settings → in the device tab: AMS interface: one click dropdown list and select filament profile → DONE! PRINT! EASY!!
When you calibrate your flow and PA it will be in ONE SPOT. EASY. EASY. EASY
LETS MAKE THIS HAPPEN!!! Please for all users and their work flow efficeincy.
