The most obvious difference on a top layer would be speed… typically lower (by default) than solid infill layers underneath. Plus the movement of course, vs. the walls. The flow could also be adjusted separately for top layer, but isn’t by default.
The filament profiles can limit the overall maximum speed (max. volumetric flow), for all features (walls, top, etc), but the preferred per-feature speeds are determined by the process settings.
If you set the internal solid infill speed to match the top layer speed, does it knock on those layers also?
(Wondering if you can dial a speed range at which this happens, perhaps irrespective of filament type.)
Anyway that would just establish a “resonant” frequency, not the underlying cause. Personally I’d go through and look for anything loose or could otherwise move to cause the extra noise (hinges, lid, panels, rods, tubing in the back… anything). Several times if I have to. But if you’ve exhausted that inspection route, then I’m at a loss.
Also, the printer definitely does make different sounds based on what/how it is printing… those diagonals tend to have more of a “chugging” sound on mine when it switches direction, for example, which I’ve noticed. Not to say nothing is wrong here, but it can be hard to judge, for sure.
Have you moved the printer to a new surface since you remember it sounding less loud? It may be dancing in a different way on the floor vs. something more flexible like a cabinet or table top.
As another experiment you could edit the printer preset and lower the X & Y “jerk” limits, which should make those direction changes smoother (might need advanced mode enabled in Studio to see those ,not sure).
-Max
