As someone who has printed and sold 100’s of lightboxes, there are a couple of possibilities here.
Are these actual gaps or white print in the colour match?
When uploading your image in to the lightbox maker it matches colours in numerous shades.
When you reduce the number of colours, it often get’s these shades wrong.
As an example. My Avatar has only 4 colours. Red, White, Blue and Black.
When loading in to LightBoxMaker (LBM) it assigns 11 colours
When I reduce it down to 4, I get this
Manually changing the colours gives this
Which looks fine until you zoom in
There shouldn’t be, and never has been Blue in the W.
There are 2 options to solve this.
- a better quality higher definition starting image
- zoom in to the pic and click on the offending wrong colour. It will then let you change the colour of that part, to one already selected. This will give you a perfect colour match, although it can be very time consuming on larger images which started with more colours and different shades.
It will show you which colour the part is currently selected. Here blue, simply click the red, and it will change the offending piece to the intended colour.
If the issue is actual gaps in the print, this is likely due to your nozzle size not being fine enough to get into the sharp turns. If you can’t reduce the nozzle size, you may not be able to get the definition you want.
My solution to this is to use the diffuser option.
This can put a single solid layer over the back of the print. It won’t eradicate the tiny pinhole gaps, but it will make them less obvious to see as you won’t get the bright light shining through.
Hope that helps?
