Hello,
I’m having an issue where the top surface shows a long visible line.
While printing the top layer, the printer doesn’t complete it in one continuous pass. Instead, it moves to print other areas of the model (small square shapes in this case) before coming back to finish the top surface.
This change in print order leaves a clear line across the surface, affecting the final quality.
Is there a slicer setting or option to force the printer to finish a surface area before moving to other parts? Has anyone found a fix for this behavior?
Thanks in advance!
