Lines on Portion of Part Facing Down with Supports
Using the P1P, with PLA Matte I’m having issues (shown in picture) with one particular portion of the part. The section of the part shown is facing downward and has a slight angle and is where supports attach as a result. I’ve messed around with changing the top Z distance but that doesn’t change much. I have set slow down for overhangs on, have outer wall speed reduced to 170 and tried 150. I’m next trying to re-orient the print on more of an angle versus flat to see if that works. Any help is appreciated.
does it really need to be floating like that? 1) can the angle be steeper 2) can it be an extra part that you attach later? 3) maybe you can add a structure that you cut later with a knife? (I assume this part goes in a slot later)
