Linux mouse speed in prepare window
The mouse speed within the prepare and preview windows is not the same as general mouse speed within Linux. Is there a way to disable this feature and keep mouse speed consistent?
(running Linux mint)
Do orcaslicer and prusaslicer behave the same?
Checked with both and it’s not a speed problem as much as it is a refresh rate problem specifically with the Prepare window of Bambu studio, it doesn’t occur at the same rate with prusa or orca. Mouse movement over the build plate is not smooth, aka the mouse appears to teleport across the screen in short bursts rather than as smooth movement.
Just to confirm, are you saying the problem doesn’t exist in orcaslicer?
If you got some time, can you try bisecting a bit, maybe go back a year or 2 in studio and see if the problem is there? We might be able to narrow it down to at least a release.
