Loud knocking during printing. Suspected Z axis but dunno anymore
My printer made this noise while printing PA6-CF. I switched ‘z-hop’ to ‘spiral’ mode and now the noise is gone or at least even more silent.
Interesting some of you had this happen on 01.02.
Thats on H2C, last firmware was release in June, and thats the one thac has caused it.
It seems the new firmware aggressively turns the rod clockwise then counterclockwise to the point it takes up the slack in the threads in both directions.
Not sure about this one. Why would it only do it on the rear screw? All three are mechanically linked with a belt and turn synchronously, with the same speed and acceleration.
Its not the nuts, nor slack in them. Its the Z motor making all the noise, which is right next tot the rear screw, which is why it appears its the rear screw/nuts making the noise.
For everyoby else this works the opposite. Spiral makes the knock, Normal removes it.
Well, I am not worried about it in my case.
  1. Firmware caused it. Reverting removes it.
  2. Nothing is broken. In my case.
  3. If it was broken, the sound would be there with either firmware…AND there would be end play of some type somewhere etc etc.
Because it is very loud, Ill swich back again from the new firmware 01.04.00.0 to the old firmware 01.03.00.00 on the H2D. Ive seen no difference in print quality.
Good luck on a resolution. Ill keep an eye on this thread.
May be I can offer an explanation although still an unverified theory…
I had experienced that knocking a long time ago when latest firmware was released for H2C. As this thread had not even started I did not correlate it to the new firmware. Instead, I suspected excessive wear in the nuts (there were) so I replaced them but with plastic nuts (using my repair kit) while I waited for the new leadscrew kit from BL to arrive. I’ve never installed the new brass nuts and never experienced any printing issue with my plastic nuts and the knocking was gone so they’re still installed…
From @DP28 post above though, he may be up to something as while the brand new nuts have no axial play, they have a lot of lateral play certainly to counteract any nut to leadscrew misalignment (my plastic nuts have minor to non existent radial play).
If the nut is not perfectly concentric to the leadscrew the rapid up and down movements can lead to nullify that clearance on the way down and again on the other side going up creating the knocking. It may be more progressive on the previous firmware and even if it may occur it simply is silenced.
Depending on the concentricity, it may be more or less obvious depending on the printer and may explain why some have not experienced it.
If I had the issue (I had it but fixed it very differently), I would loosen the 3 nut screws a bit (they are red loctited so hard to break the bond, use HIGH QUALITY hex driver to avoid damaging the screw hex), I would bring the bed down until it contacts the bottom of the printer and retighten the screws on an alternate pattern to make sure the nut is concentric to the leadscrew (there is no lateral play of the leadscrew at the bottom so that’s where it needs to be done). I would then retest to see if the knocking disappears.
This is a completely unverified theory just gathering the facts expressed in that thread and given the numbers of stripped nuts on H2D/H2C I would understand you don’t want to mess with them just to verify the theory… :smirking_face:
I think z axis nut also. Checked the z motor and it appears they do not have end play.
Oh that’s interesting. Z-hop was first configured to ‘auto’ and generating the ‘knock’ noise. I switched to ‘spiral’ and the ‘knock’ was clearly reduced. I will test the other settings.
I just experienced this on a brand new H2D. Rolled back the firmware to 01.03.00.00 and it resolved the issue.
So worn Z axis nuts would not be the issue.
This has been brought up before and both my personal and work H2D’s started doing it after the last firmware update.
There is a new beta (V01.04.15.00) out for the H2D, that might be fixing the issue, but as I don’t have the knocking issue, I can’t verify that it’s gone also.
There are no release notes on this version.
With the newest Firmware 01.04.20.00 the knocking on my H2D is still there.
woowwww, that is some real nerve.
