Manual PA Profil doesn't seem applied on A1 printer
Hello,
I am using Sunlu PETG Basic filament with Flow Dynamics manually calibrated.
This is what being used. I tried to print a Bambu Cube but without the option “Flow Dynamics Calibration”. I expected that it would take the PA Profile i calibrated that is associated to it but the print have the same problem over and over if i don’t check that box… there seem to have some under-extrusion in a specific corner… but if i check that box… everything is perfect. I wanted to use a manual K factor instead of the auto calibration.
Here without the option “Flow Dynamics Calibration”:
Here with the option:
If i look in the printer… it doesn’t seem to have my filament or any profiles i manually calibrated and created.
How do i print with the PA profile applied? It is supposed to sync the PA profiles with the printer? Is there a way to see if it actually use my PA profile?
Thank you!
Did you ever figure this out? I’m having trouble with the PA profiles too, I’m just using the built in Bambu calibrations but it keeps not displaying my PA profile as available.
