Material from Zortrax
Hi All
I have a lots of material from Zortrax
Is some one know how to create the new material in the Bambu lab
for example Hips : https://zortrax.com/filaments/z-hips/
It is not the same value .
regards
Is this what you are looking for?
https://wiki.bambulab.com/en/bambu-studio/create-filament
No
I need the data to fill in bambu studio
Ok.
I doubt that you’ll want to use a cool plate for HIPS (warping). The 0° is used to highlight incompatibility.
A nozzle temp of 240°C is recommended here: https://filament2print.com/en/hips/1235-z-hips.html
But I’d print the first layer no cooler than the subsequent layers.
You get the flow ratio from the flow calibration. Afterwards, also calibrate Flow Dynamics (also known as Pressure Advance).
Hi
Thank you
How can I get the flow rate from the calibration ?
regards
In Studio, you have several options to perform filament calibrations.
The easiest is probably the older calibration tab (same line as Prepare, Preview, Device,…). With an X1, you can use the auto-calibration. Or, to start to get a better understanding, try the manual calibrations.
