Misplaced message when opening a A1-profile with "print by object"
–I already posted this in the makerworld-section. But it probably belongs here.–
When opening a profile for the A1-mini with “print by object” in it, the slicer gives a warning that timelapse does not work and gives the choice if you want to continue with “print by object”. That choice is given at the wrong time and is at best a message at the right corner. Of course this is meant to be a desired setting and timelapse is secondary to that.
example : Cute Christmas tree with shoes by PrintThatBoii - MakerWorld
(A1 with AMS -1 Plate, two separate printed colors).
If you choose “No” in the given example you go from a print with 1 filament change to a print with 191 changes :slight_smile:
Probably belongs on the github honestly
Yes you are probably right. Sometimes the I loose track :slight_smile: I will post it there and remove it here, thanks. Edit: for some reason I can’t remove it
