Hello,
Recently I’ve been experiencing the following issue:
I’m using Siraya Tech PPA-CF Core filament on my H2S, fed via the external spool holder. During filament loading—before the actual print even starts—the filament breaks inside the PTFE tube, shortly before the extruder.
The tube is not kinked, and I even replaced it with a brand-new one as a test. The external filament path forms a smooth, gentle curve. The filament can be threaded through the tubes very easily; there is no visible kink, tight bend, or constriction.
As another test, with the motors disabled, I moved the print head multiple times across the entire build plate to all possible positions. In this scenario, the filament did not break a single time. A further successful test was printing without the feed tube at all—feeding the filament directly from the spool into the extruder.
Previously, I was able to print at least 10 spools of the same filament without any issues. I also tried a second brand-new spool and encountered the exact same problem. Extensive drying did not help either. I initially suspected a defective batch, but even so, I don’t understand why the filament breaks at all when it otherwise moves freely.
I’m aware that this filament is on the brittle side, but I’d really like to learn and understand how such a break can occur in this situation. Has anyone experienced something similar, or does anyone have a tip or explanation?
Thanks in advance.
