Model Theft or Remix? Help Me Decide!
Agreed :+1:
Another aspect to consider in this case, is the NC terms. One could argue that the rewards system and contests are infringing those terms.
I asked to ChatGpt ^^, this is what it has to say about this :
Under the CC BY-NC (Creative Commons Attribution-NonCommercial) license, the work can be used freely as long as it is not for commercial purposes, which generally means no direct monetary gain from the use of the work.
However, whether receiving rewards per download or winning a contest with prizes constitutes commercial use is a nuanced issue:
  1. Receiving rewards per download: This could potentially be considered commercial use, depending on the nature of the rewards. If the rewards have monetary value (like cash, gift cards, or other incentives), it may be viewed as deriving financial benefit from the use of the work, which could violate the non-commercial clause.
  2. Winning a contest with prizes: If the prize has significant monetary value or the contest is designed to profit from entries (e.g., through advertising or ticket sales), this could also be considered commercial use. The key factor is whether the prize or contest creates a financial benefit.
In both cases, the interpretation depends on the specifics and the nature of the rewards or prizes. If there is doubt, it is advisable to either avoid using the work in such contexts or seek clarification or permission from the original creator.
I stayed away from the subject.
My opinion: whoever organises a prize, no matter what form it takes, should insist that the designers applying only submit models that they have created themselves (and are therefore original to the designer). However, it does happen from time to time that people submit something for someone else in a competition (so that this person then wins the prize).
I agree with this wholeheartedly. Contest entries should be limited to only original works posted by the original designers. No remixes of other peoples’ work.
Just don’t upload models if you don’t wany them stolen…because THEY WILL BE STOLEN at some point…
So here’s a case-in-point about this situation that I hope gets some attention as much as the rest do:
The latest viral model in 3DP is the Scott Yu-Jan iPhone Standby Mode Dock, with dozens of dupes and remixes without credit, several of which have the AUDACITY to set not only NOT credit as a remix, but set the license the restricted, like these:
I’ve reported the ones I’ve found, but this is case-in-point the problem that I hope MakerWorld sees - they created a collaboration with a famous influencer, and the dozens of knock-offs (not even remixes, just dupes) are already flooding MakerWorld. They need to send a signal to MW users that this will not be tolerated.
There’s a catch here with CC vs “Stadnard File Licence”
In case of
The fact that it’s a remix is correcly stated. The credit is given to original author via remix feature of MW. The more restrictive licence of remix is compatible with original licence of Scott’s work because it’s licenced CC-BY-NC without either ND (prohibiting remixes) or SA (prohibiting change of licence) limitations.
However here:
The situation is different - the design could be made from scratch. If it was indeed made from scratch and used video as an inspiration and built it from ground up then it’s somewhat fine. I’m leaning towards considering it different built due to the way of internal structure.
Last one however is clear
This is uncredited and unlinked remix.
Top one: they changed it to add remix after I posted
Middle one: you can overlay the geometry on top of eachother it’s the same exterior cad
A lot of scumbags out there.
It strikes me though, it would be really helpful to have an option to ‘attribute’ boosts from a remix to the original model. There are times where only minor tweaks are made, but that tweaked one for whatever reason takes off - if would be nice if the person uploading the remix could just say (at a settings level) “all boosts will go to original uploader”.
Other times a remix is so extensive it is basically its own thing, and sure those people deserve to reap the credit - but at least giving an option for people to do the right thing in a formal way. Surely couldn’t hurt?
I’m experiencing something similar to that last comment’s end statement currently. I have a post about it here.
I posted my original model, and i boosted the model that i suppose inspired me to create mine. I even gave kudos to the creator in my model description. I am now met with a copyright strike on my model.
How is this encouraging me to post more models? Or boost ones i find well designed? It isn’t.
it is a complicated issue COPYRIGHT.
to fully protect a design, Patent it. But that is not cheap. And it is not a guarantee you will not be “remixed”.
Depending on MW to be the arbitrator has lots of pitfalls. I have not looked into MW rules in a long time. I assume they have a process that is quick and easy. Or in other words it is “not always fare”.
