Thanks for this, I was using a Python script to try and pull data from my A1 using MQTT and getting connection refused, yet the same A1 credentials work fine in HA and NodeRed - and all works fine on the X1C, so maybe the local lan is required on the A1 for direct MQTT query- I cant even get MQTT explorer to connect for basic status messages… 'Error 5 Connection refused"
yes, send this message via mqtt to your printer
"pushing": {
"sequence_id": "0",
"command": "pushall",
"version": 1,
"push_target": 1
and it should return a bunch of information but the item you are looking for will be called “mc_remaining_time”: and that is time left in minutes I believe
