Dear forum,
I wanted to print a cup with multicolored rings on a cup over the height of the cup. I selected all the different colors with the slider after slicing. If I put some text on/in the bottom all the colors are gone and changing colors is not possible anymore. Right click on “change filament” is now grey. What is the problem here? Any ideas?
Thanks for helping!
Greetings thegag
It is difficult to visualize the problem without a screenshot.
As I understand the problem, it may help to realize that text on an object is realized as an assembly. So switching from Global settings to Object settings allows you to select each text block individually to assign materials.
Personally, I find Studio’s text handling both very cumbersome and ingenious at the same time.
Cumbersome for text placement, changing, localization, etc
Ingenious once you realize that you can change the text object from a part to a negative part or even modifier.
Hope this helps:
Change filament is grey and not possible.
