I want to print six copies of a simple part on the same tray, but at different temperatures (220-225-230-235-240-245) so I can see the difference in how the material prints depending on the temperature. How can do that?
If that is not possible, can I print a simple colum and each 5mm (for example) change the temperature the same 5 degrees?
Thank you
Ok, if nobody knows how to do this, perhaps someone knows how to print several items at the same time, but varying the flow ratio for each?
Yes, have to enable Dev mode, then go to Process → Objects → Quality/Advanced:
It’s called a “Temperature Tower” calibration. The printer already knows how to do this. One object, printed with different temperatures as a function of layer height.
Great.
So, how do I do this?
Orca will generate a temp tower calibration print. For some reason, the Studio fork doesn’t have it.
