Multiple printers in projects
I have two printers A1 MINI and P1S, I’m trying to print the Jet engine kit, but I want to split up the parts into the two printers. What I’m saying is that BBL should make it so you can add multiple printers in one project. This would help for multiple projects expecially for people who have multiple printers and wanting to print something huge.
I really hope that they add this
You can change the printer and it will rearrange the parts.
I used the same combo to print the engine once upon a time. Once it rearranges then send your print, then go back.
There are some hurdles in what your asking. Settings are different for the printers and keeping them sorted as you flip through plates would be difficult.
When I set up my print for it I set the bigger plate parts and saved it as “engine 1” then I set up all the Mini plates as “Engine 2”. I could load either into BS when the respective printer was done. Not what you want, but since you can’t do what you want it’s an idea of how to set it up. Wait until you’re dealing with more printers, it’s fun.
This gets a lot easier to do if you save all the profiles. That way selecting the machine to run the correct plate is only really:
Machine → pick, will reload a bunch of stuff
Filament → check if default is correct, or pick
Preset → check if default is correct, or pick
And the software won’t assault you with “do you want to saves” between each step.
