My brand new A1 is Wacko! Help!
My Grandfather was a carpenter back before then. I’ve heard that saying, sometimes referring to me.
My Bed hasn’t hit the wall since my wife went thru menopause like 25 yrs ago.
I hope your cable is at least rubbing against something though.
I feel your pain Bro!
Extra characters
Uh… Why does it need to rub something?
At least your print isn’t rotated 90° clockwise. Every time I try to use the Bambu Studio to create a print it ends up rotated 90° clockwise of how it appears in the software. It’s weird.
do tell
Are you using someone else’s files, or files you’ve drawn in a CAD program?
Have to ask, but you are using the A1 printer profile? I have never seen the purge/flow calibrations lines that long before on an A1, only on the X/P series.
To recalibrate, its on the A1 its self under Setting > Maintenance.
Home the printer first, then run all printer calibrations, make sure Bambu studio is closed to prevent conflicts. Once done power off the A1 and power backup again to prevent conflicts.
If this doesnt solve it, id try and get it swapped.
I had the same problem It was easy to fix. I rotated the printer 90 degrees counterclockwise now the print is corrected automatically. Happy 2025 fellow printers
