I wanted to share an experience that happened to me this week and the journey that has resulted in me losing most of my Maker World points and having me reconsider the program.
Mid last year my 5 year old son requested that I make him a train switch for his track. I wanted it to be a learning experience for me that would allow me to learning CAD software as well as nurture his love of engineering.
After a few months’ worth of work, trying different software I finally released my first model on MakerWorld, my original train switch. While similar to other models, it was something that I completely developed myself, especially that snap fit arm that connected the parts. This model popular and was appreciated in the community.
However, I noticed a minor flaw in the design that bothered me. If the arm was set to guide a train to the side, occasionally a heavy train would be able to come along and push switch back to its original position, resulting in the train moving forward down the incorrect path. Friction is all that was keeping the switch in place.
I then embarked on creating a new version that would allow the switch to lock in place. After a few more months’ worth of development I created a Lockable switch that I was immensely proud of.
It was unique for the following reasons:
1 – I implemented the locking mechanism that no other similar switches used.
2 – I made use off all female design connectors. This may seem trivial, but I believe it is what sets my train designs apart from others. My son is not able to plan a complicated layout, but he loves adding complexity. However, when switches are involved, he always ends up with connectors that don’t meet, as they are both male or female. By switching to all female connectors with drop-in adapters, he is able to build more complicated tracks, knowing the switches would always connect.
3 – I halved the numbers of models required to build a switching layout. Where you would normally require 4 differently shaped switch models, mine design resulted in you only needing 2.
However, when I released my model, I was concerned that the tolerances used in the locking mechanism would not print well on other’s printers. In order to mitigate this risk, I released the new design as a new model, with the intent of not ruining the reputation of my first design, just in case the locking mechanism was not printing universally. The two work very differently internally.
Initially the original model remained popular, and no one showed interest in the improved lockable version. I even went so far as to place a notice on the main image of the original version to download the lockable version.
For months things were slow but eventually after many red banners, deprecation warning and requests for customers to use the Lockable version, the lockable version took off and became more popular than the original version.
At this point I enrolled nearly all models in the Exclusive Model Program as I had grand visions of being the one stop supplier for Brio compatible train track and accessories. I dusted off my old G16 camera and took new photos of all my models, with a lightbox and went so far as to post process them.
My switches became the two most popular switches on MakerWorld. By my estimates I was going to make a few hundred in USD this month in Redeemable Cash. (Which for me is a significant sum).
Today when I woke up, I discovered that my new Lockable version was pulled from the Exclusive Model Program and that I was penalized for lack of creativity, and I lost a few thousand points. To rub salt in the wounds, they left the originally deprecated version in the Program.
I do believe that what I created in the Lockable version was unique and better than all other available switches. I understand that visually they may appear similar, but the mechanisms for both are different and unique.
I have created a support ticket to appeal, and requested that I would happily delete my original switch to have the new improved Lockable switch back in the program.
I also removed a large number of models from the Exclusive Program as I simply can’t take the point penalty again. Such a drastic action without warning feels like its punishing creators who simply want to make MakerWorld their home.
I plan to keep others informed of the process in case something similar happens to them. I will let others know if I am successful in my appeal.
