Some how it looks like the sample filament “support for PLA/PETG/ABS” that comes with x1c. I tried to print in PLA profile by mistake and it came out nicely, but shortly after that it fell apart like knitted jumper turned back into lengthy yarn. Turn out that support filament was kind of alloy from HIPS apparently.
Have you tried to increase temperature, say 220C to 250C or higher? Addictive-like figment does change some temperature property of the filament
I’d suggest to run through the recommended maintenance, in particular cleaning and belt tensioning as well as re-cleaning the extruder and replacing the nozzle. Then re-calibration, cutting the front 10cm of the last filaments and see if things are back in order.
I did the same thing once and it bent my hotend. Do you have another hotend? Maybe your got bent slightly like mine did and its causing a slight jam during the filament extrusion. I would just replace the entire hotend with a new one. They are like $15. Also I would do a belt retention procedure. Maybe it caused the belt to jump teeth. When doing it make sure the gantry hits the back of the print on both side at the same time.
