Hello, tomorrow I’ll get my first 3d print (Bambu Lab A1 with PLA filament + an aditional 0.2mm nozzle), and I want to print this type of models but I don’t really know what settings should I tweak to make it look good + eficiency.
It doesn’t need to be very strong as it only is for decorative purposes.
What settings should I use?
Thanks for the help in advance!
Edit: It is around 60 x 70 x 100 mm
Much of the default settings will be great.
You will need to enable support for things like the hands and ears which cannot be printed without them.
I would recommend changing the default infill pattern from grid to one that doesn’t have a travel path that goes over the same area on the same layer. I use Gyroid, you do you.
The infill percentage will likely only need to be low, 10% or lower.
If this is going to be purely decorative (not played with), use infill pattern lightning this works by only be located where absolutely required to allow structures printable internally rather than starting from the base. Think; it would appear from the edges to support the top of an egg, no support would touch the internal base.
The best way to learn is to tweak one thing for each print and see if/how it made things better or worse.
Thank you so much, i’ll try that! ^^
