Need Help,Print Lifting Up Left Side Bed
I sure hope these aren’t the same issue or that would imply something systematic like a bad design or a common production issue.
But it sure could be. Now I want to map my print bed. I don’t have an IR camera but I do have an IR thermometer.
As a counterpoint, when I have had lifting, mine has been in the right rear part of the build plate. I now am wondering if it’s a little cool there.
if you go on ebay you can get a Flir One for your phone for 150$. Its also useful for finding insulation problems in your home, really useful, but very easy to lose.
After seeing those images and realizing what all I could use it for I ordered a Hikmicro. Not as nice as the ones you guys have but apparently pretty capable. Very curious how this will all play out.
Old subject but I’m experiencing similar with large flat signs that I print.
Using the same bed the machine came with (Textured bambu plate).
  • I’ve been printing these signs since April/May 2024, without any sort of issue until mid/end December 2024 and the issue continues now in January.
  • I live on Long Island - maybe the humidity/climate has an effect, but i’m using the P1S, enclosed, in a basement without any draft or ductwork
  • The issue follows the left side of the item for some reason - if the signs’ orientation is rotated 90 degrees, the same side lifts, never the opposite side of the piece. WEIRD!
  • What DOES help? Glue stick. I haven’t used glue stick on my bed since owning my machine as of Feb '24, and here i am applying it against my better knowledge.
  • I suspect that this maybe providing enough tackiness to keep the piece on the bed until the end of the print
  • Someone had suggested that maybe the print bed is now junk after a few hundred prints, to replace it. IF this was true, then why don’t i get the effect for my smaller prints?
  • Another suggestion was to use a scotchbrite pad on the bed - i haven’t tried this yet, but i also dont want to waste filament if printing for a customer. Perhaps i can shrink the model down to a small enough size to see if the effect is still there.
  • I’ll be buying that blue cool tack bed as soon as it’s available.
Beds are consumables.
Beds need to be cleaned regularly.
Glue is very effective for most filaments.
Other solutions depend on the printer, filament, and environment.
So, nothing here to be surprised about…
