Need help printing pla areo
I have tried printing pla areo a few times, but every time the middle of the base printed won’t adhere properly to the bed. using 60C bed temp on textured pei plate, i have cleaned it and tried again but still doesn’t work.
use a brim + non-textured bed
is engineering plate good? i’m buying one
not sure, when I have issues I always use the flat one, for the h2d there is no engineering plate (but that one has texture still right?)
it’s a new build plate that came out this month
so use smooth pei plate?(25 characters)
you can test both but I only have the flat one :slight_smile: I know with glue in that one it always work fine, even in very difficult prints
thanks. i used the standard textured plat and it worked fine.
