Please see the explanation image below.
I made a negative part rectangle to drop a magnet into during a print pause.
It clearly lists the dimensions of this negative rectangle as having a width of 13mm, but it is printing the negative space with a width of about 10mm.
Went back into Bambu Studio and made a new negative part with the 13mm width and put it side by side with the original. Even though the width (in this case the Z dimension) is clearly listed as 13mm for both of these separate negative parts, they are distinctly different widths. The original is about 10mm (judging by it being a bit over 10 grid squares wide), and the new one I just made is the proper 13mm.
I’m stumped, any insight much appreciated. I do see that the percentage above the Z dimension varies between #1 (the original rectangle) and #2 (the new rectangle I made for testing), but that shouldn’t matter, right? Isn’t that when I scale it manually up and down in size, the dimension in mm changes and should be accurate, shouldn’t it?
I’m stumped, insight much appreciated.
