If this price translates over as a pure conversion and there are only 7 colours available, I have massively overbudgeted for one of each!
tomorrow its the build plate
im so exited but wat was the tpu for ams made ithink ist defenetly not gonna be normal tpu isnt it
It has Shore 68D which appears to be pretty hard.
Most country stores are already out of stock of many colours despite only just becoming available in the past few hours and significantly more expensive that it sells for in China.
Did the new plate release?
It sure did, also code “Supertack” will get you an extra 10% off…
SUPERTACK discount code isn’t available to you right now
In case people may miss this part. Because the plate was mentioned along with tpu by the op
How to remove prints from SuperTack
(The instruction below shows you how to remove the prints without damaging the coating)
Use the scrapper included with your printer to gently lift the print, then pry it off carefully. If the print is sticking too tightly, heat the plate on the heatbed to 50°C to assist with removal
Considerations
-The surface is soft. Be careful when using a scraper to remove printed parts.
-Do not print with TPU filament, as it will damage the build plate.
-Increasing heatbed temperature enhances adhesion. Users need to adjust the temperature of the heatbed based on their specific requirements in order to achieve the most suitable level of adhesion.
-Before auto-leveling, it is necessary to repeatedly rub the nozzle in the special wiping area of the build plate to completely remove any residual material at the tip of the nozzle. The coating in the special-designed wiping area will gradually become worn over time. This is normal and does not affect print quality or nozzle lifetime, so there is no need to worry about any quality issues.
-Bambu Cool Plate SuperTack is considered a consumable part, which will degrade over time. The warranty will only cover manufacturing defects, not cosmetic damage like scratches, dents, or cracks. Defective sheets upon arrival are the only ones covered by the warranty.
-SuperTack provides good adhesion without adhesive or frequent cleaning. You can clean the surface with water and detergent if heavy dirt appears. Do not use organic solvents (especially acetone) to clean the build plate, as it will damage the SuperTack surface.
eu.store.bambulab.com/products/bambu-cool-plate-supertack this is the build plate link and this is the tpu for ams link eu.store.bambulab.com/products/tpu-for-ams copy and paste them in
theve lunched the wood like pla its called the pla wood
