New to 3D print - PETG frustrates me
Hi DanielT,
I am in the same boat so do not worry at all :smiley: . Whatever you do with X2D you will need to spend time to dial it in, at least this is my experience so far!
Now from Bambu PETG easiest should be HF but not in sale anymore, now they have basic and matte. Basic should be easier but obviously it is not matte. Absolutely no warranty that basic will be absolutely PnP either. So if you like how it looks you need to spend time to dial it in. If no try something else.
As I said above I found the standard calibration tests as very approximate and base guidance, both line and pattern. And fine tune is better with real object, at real speed with specific layer parameters. This is of course for me. Here we have guys running all on auto and swearing all comes out perfect … good for them. But this is not my case with neither X2D nor A1 mini. So maybe we just have different expectations. :smiley:
Got to point out that drying until no weight change only means that the drying method has given its all - not necessarily that the filament is dry.
Things that limit dryer performance are low/no air exchange with the dryer and high ambient humidity.
Big weight changes do point to more effective drying but doesn’t mean filament is dry.
PETG is particularly problematic for water issues. Anyone having issues printing PETG likely could improve their filament drying technique.
True, I use an old harvest farms food dehydrator. Doing it the way I do, I’ve yet to have a moisture problem and my rolls seem to stay dry for months in sealed containers, according to the hygrometers I keep in there. I generally only have to recharge the silica about once a year.
Dehydrators can work well for drying. I’m not in any way saying your drying is ineffective.
I was just pointing out that weight difference to determine dryness is problematic advice because others propagate an added incorrect tidbit - that no weight change means filament is dry. Many think no weight change means all the water is gone so any print problems must be something else which is incorrect.
A good way to know the state of filament is to put a spool in a sealed container - even a gallon ziplock bag - with a hygrometer and read the humidity after it settles. Filament can hold about 1000 times more water than the air in a container a little bigger than the spool. The filament dominates the measurement and you get a humidity value representative of the filament moisture.
For my setup I start seeing typical water issues with PETG with a room temperature RH number higher than around 20%.
