Newbie question - files settings not appearing
Apologies in advance if this is a silly question - I am still learning! I have an A1 mini and was under the assumption that when you download a .3mf file from MakerWorld and import to Bambu Studio, the settings used by the creator should appear. That doesn’t seem to be the case for me. Any file I download to Studio from MakerWorld does not appear to display the settings from the creator…
For example, today I found a file I wanted to print that had 100% infill and I wanted to decrease the percentage. When I imported to Bambu Studio, the infill says 15% (standard that always appears for the filament type). However, it will print at the 100% as the creator originally intended. I have the correct printer profiles selected when I extract the file and in Bambu Studio, I do not have any custom profiles saved (I only have PLA Basic from the dropdown), and the .3mf files have all been compatible. I have also tried to import the file different ways to see if that made a difference - it did not.
What am I doing incorrectly? I would love to view the print settings accurately so I can adjust accordingly if needed. I feel like I must be missing something very obvious?? Any insight is appreciated. Thank you!!
