As you can see on my photo some comments above, it was located at the location of the chamber cam. This was before the chamber cam was given free as gift and it wasn’t available anyway. It was a 2 part solution: The cam module was in a chassis inspired from the original chamber cam and located in the original location and the ESP32 module is located below this location, mounted on the frame. The cam module has a 120° lense with a 75 mm cable connector.
At the moment it isn’t in use. But I’m thinking of redesign and rebuilt the chassis to put it on the same location at the right side of the P1P. So I can have both active. Then I can use the chamber cam for timelapse (if Bambu Lab improves the timelapse quality) and the ESP32-Cam for live watching the print.
