No. I am talking about the layer at the bottom of the test object which is shown in the image. The image shows the bottom of the test object from BS.
Orca has a brim but no first layer covering the bottom of the test object.
I may not be describing very well.
BS prints this object in a way that it could hold pencils in it. With Orca, the bottom does not exist so that any pencils placed in between the walls would fall to the ground
A brilliantly simple solution! I am a little embarrassed I did not think of it.
I will try it when I get home tonight (do not go rob my house just because you know I am not there…there is a very large dog guarding the place and he knows how to use a vacuum) and if it works like it should, I will come back and mark this as solved.
I make stupid jokes when a likely solution is found, especially when it is so simple.
